Re: Force 115HP head torque specs
225 inch pounds in a spiral pattern from the center two bolts out. Torque in two or three steps. (for example: 150, 200, 225). If it is a new head gasket, re-torque after about 1/2 hour running. No need to re-torque a used gasket--it will not compress any more under heat
