88 Force tilt/trim dead
CoreyM.
Hello to all!! (first post),<br /><br />I have an 88' bayliner capri1750 w/ a 85hp force (outboard). When I tried to run the tilt/trim the motor I could hear it trying to run then stopped and now I get nothing. I made sure the battery had a good charge, but every time I try to run the t/t it trips the breaker inside the motor compartment.should i be checking my relays or a solenoid??? please help!! And thank you in advance!
