I have a early to mid 70 year Chrylser 35HP motor. THe moter has been sitting for a few years and was not pumping water when I fired it up a few weeks ago. Changed the water pump and put it back together and it is not pumpimg water the whole time. We have taken it apart several times and even used gasket sealer. THe water lines are open, we sprayed water up into them and the water poured out. When I start the motor no water, if I increase the fast idle then water will pump out and stops when a turn the fast idle down. <br /><br />Does anyone have a diagram they can send me of the lower unit and the water pump and how it goes together so I know it is correct? ALso the water pump sits on a metal plate. someone said there should be 2 plates, one on the top and one on the bottom, is this correct? I only have 1 plate. DOes the water pump need to be completed sealed except for the hole in the bottom plate? <br /><br />Thanks for any help.
