lukethorwart
- May 8, 2005
- 28
1998 Bayliner Capri 1800 with 120 hp Force.<br /><br />Probably something many people have experienced. Get the thing to the water, and the steering is seized up. <br /><br />After reading quite a few articles, I am still not comfortable with what's going on. I can actually turn my wheel about a quarter of a turn both clockwise and counterclockwise but of course, the outboard does not respond when I do this. I'm not pushing it at this point for fear of stripping something in the front part of the system. <br /><br />I am now pretty sure that it's probably realted to corrosion of the cable somewhere in the tube. I don't have a diagram of this tube or of the cable so I'm quite uneasy about doing anything to it. I think this is probably something I can handle, rather than taking it to a shop and waiting until the middle of boating season to have my boat back.<br /><br />I got the gist of removing and replacing the system from some other posts, however the real problem is that the motor is stuck in place such that I can't get the tiller disconnected from the steering rod. I took the lock nut off that connects the two but I can't get the clearance to move it out of the hole where it connects to the steering system. Any suggestions (aside from taking the motor off the transom?)<br /><br />If I could do this, I could test and see if the engine swivels and once that is verified, remove the large nut and try and back the rod out of the tube.<br /><br />Finally, once I remove this large nut on the left side of the tube, (I'm looking at the motor from directly behind it) there is another fairly large nut and what I think is a tension type bolt on the right side of the tube. Do I have to remove these as well?<br /><br />Any help or direction would be great.<br /><br />Thanks in advance.
