Re: 85 hp force firing/ electrical problem
I had the same problem with a 1986 - 85HP Force, I found that some of the wires from the CD boxes ( I had the crow foot connections ), were broken inside the wire insulation, I ended up replacing both CD boxes with CDI components & I replaced the Stator, as it started to have some bubbling on the coils ( after all these parts are 18-19 years old and prestolite electronic parts don't age well ) the trigger assembly realy doesn't go bad, so I didn't replace it, the boat has been running realy good since the electronics have been upgraded, oh you might want to have the spark plug coils checked out, if the internal electrial specs are out of spec, it will take out a CD box.
