I have gleaned this info from this forum and I'm asking for confirmation regarding this proceedure.<br />Cold starting 1991 90HP Force:<br /><br />1)pump the fuel line bulb (until it is hard) before attempting to start<br /><br />2)independant throttle control when in neutral-open the throttle about half way <br /><br />3)electrically actuated choke- turn the key on, then push in for about 3 seconds then release, then turn the key to start."<br /><br />possible problems preventing - start up<br /><br />1-fuel pump needs a new diaphram<br />if the diaphram is bad, it leaks fuel into the block and causes it to flood<br />2-check that all cylinders are getting spark<br />3-plugged fuel filters<br />4-clean up the carbs<br />5-The Stator will work...or it will not work.<br /><br />Does this info sound correct?
