I am new here and new to boat engine repair. I have searched the site for an answer to my problem and come up with a list of items to check in order of easiest/cheapest to do. I would like to post my issue and see if there is a better recomendation or different order to my checklist. I am by no means mechanically inclined when it comes to motors but I do have some friends who are.<br />Problem: Purchased 85 Bayliner w/ 85 125 force in 2004. Have run the boat 4-5 times a week all this summer pulling wakeboarders, skiers etc. yesterday morning boat ran fine, last evening took the boat out for a run... after 2 mins of open throttle rpms dropped from 6k to 3k (not really sure my tach is operating OK- always shows 6K at 3/4 to full) and just stayed there. was able to limp back to dock at 5 mph.The change in RPM was smooth, like I had throttled back. At dock cleaned and checked plugs, nothing out of the ordinary. Boat fired right up after 2 mins of running on lake again same thing happened.<br />Here is my list of options:<br />Check fuel filter<br />Check for loose wires on motor<br />(already checked plugs/wires)<br />Check fuel lines? <br />Check Air intake for gas tank?(not sure where that is) <br />Compression check- friend says he can do for me<br />Check carbs for build-up/clogging?<br />Replace Stator?<br />Please advise if this is correct order or I am missing something. Thank you in advance.
