My temp buzzer started to sound after I replaced the CD Power Pack. Before replacing the power pack, the Buzzer never sounded during engine start up or at any speed. Then it began to alarm at 30 MPH. After slowing down, it then began to alarm @ 20 MPH. Loaded it up and went home. I replaced water pump impellar with kit(old pump wear plate pretty worn & gouged)and installed new thermostat. Haven't started the motor yet, as I am hoping for any other suggestions before adding gear lube and dropping in water. Anyone know how to test for defective buzzer?
