Re: Chrysler 70hp shifting
I hate to sound elementary on this, but can you shift it into gear manually while the motor is off? If so, you probably have a problem with the clutch dog and /or gear faces being worn. If you cannot shift it into gear manually with the motor off (and turning the prop), then you may have a problem with the shift rod having come loose in the lower unit, or your pinion gear is not engaging the forward or reverse gear. You probably need to remove the lower unit and examine it for these two conditions
