peacekeeper6
- Apr 25, 2005
- 765
as everyone knows i am sure i had a bito a fire. i seperated all the wires from being fused together and was taking some readings and am getting very low resistance in the connector that goes to the front of the boat. only a few OHM open so i was wodnering if on the side that plugs into the engine side are some wires supposed to OHM together? with low resistance? i wanna rule out the connector beign melted beyond use so if i can reuse it i would like to thanx.
