Re: chrysler 45 steering probs
Worst case scenario - remove the lower motor mount and try to clean the pivot shaft by hand. Since it has been in salt water, you should be ready for those hex headed bolts to be EXTREMELY hard to get out. Soak them liberally in pentrating fluid before you put a wrench on them. I had to drill the head of one out and take the mount to a machine shop to get hem to remove the old blot.
