Re: 85 HP force torque sequence and torque amount
The sequence of the torque are as you look at the head starting at top left numbers are 13, 9,5,1,4,8,12, the ones top right are 14, 10, 6, 2, 3, 7, 11 set them up by sides and start at number one and go from there. Number one should be middle left. Hope this helps. Good luck.<br />Bob
