Re: Chrysler 60 hp fires at one cylinder only
Well, after fiddling for two weeks I've found that the number one coil was wired incorrectly. I now have solid fire at both coils. However, I STILL cannot get the thing to start. I have new fuel, Primer bulb gets hard when pumping, cleaned carbs, good fire. The compression is a little low, but its an old motor. 112 and 85. If I crank it, it doesn't even want to start. If I spray some carb cleaner in the carbs it cranks harder and stops until the compression releases a little. BTW, it had the wrong spark plugs in it so now its got brand new ones. Does anyone have any ideas before I pull this thing into the woods and let it sit there for the rest of the summer? Thanks.
