I have a 99 Force 120 that has 0 compression in the first cylinder the other 3 are fine and hit about 140. <br /><br />The boat runs fine except a little rough at idle. The spark plug from the 1st cylinder did have a silver coating. So question is, the engine does run but how bad is the damage?<br /><br />Is it possible to rebuild only the bad cylinder with what it needs? Or is a complete rebuild in order?<br /><br />Since its still running should it be run until it completely dies since a rebuild is a rebuild for the whole engine either way?<br /><br /><br />Thank you for your comments!
