Re: Cooling System Question Chrysler 75 hp - Bypass Valve
Welcome to iboats, Brett.<br /><br />The purpose of the bypass valve is to equalize cooling of the different pieces that make-up the powerhead. Without it, one piece could theortically expand at a different rate than the pieces mounted to it. Not good. It also acts as a water pressure regulator, so no gaskets or seals are blown from too high pressure.<br />The impellor is the weakest link. Replace it first, just out of principle. They are considered a maintainence item that should be replaced at regular intervals,(ever two seasons of normal use), regardless of condition, because they are rubber, and wear out fast.. They can also form the shape of the housing if the motor sits unused for 6 months or more.This is called "taking a set".<br /><br />Pull the plugs and inspect them. Look for a really clean-looking plug. This is an indication of a blown head gasket,"steam-cleaning" the plug.<br />There should be a thermostat on the top of the head. Remove this and re-test. It also serves the same purpose as the bypass valve.<br />Don't leave it out for more than just testing. Extended operation without a t-stat can cause major problems...But it may just be a stuck t-stat.<br />The cooling water comes-into the engine under the cavitation plate, at the 2" luevered area.<br />The impellor pushes coolant up the leg to the thermostat. The thermostat opens at a preset temperature, so no water will exit the telltale for a minute or two, until the temp opens the tstat.<br />The course the coolant takes from there is around the outside of the jugs,around the head and block, thru channels...Then, a portion of it goes out the exhaust thru a "heat-exchanger", usually just a part of the block's contruction, and mating surfaces.<br /><br />Good luck, and let us know how it's going.
