Motor overheated and slowed to idle while on plain. I turned the motor off and it would not start. After a hour it started after repeated efforts.The motor would die if I returned to idle. I need to check compression still.I can get it started if I idle up and keep it above 1200RPM. Below that, it dies immediately,but it runs smooth without A miss.Removed plug in top of Head to see if water was making it up there.Water does not stream out but it did manage to get everything pretty wet, fairly quick(Including me). Thanks for any input.I will put it to good use. GoodDay.
