Re: 1976 Chrysler 135 HP Timing
Info I have says Champion UL18V plug, 32 deg BTDC for timing at WOT. Idle RPM 700-750. Should have the Magnapower type II igniton sytem. <br />Source: Seloc manual.<br />At idle, I would think the timing would be around 0 deg BTDC. Timing is set at WOT only as far as I know.
