My 1972 Chrysler 45 hp is not cooling and is pumping very little water at idle and none at high speed. No water is visible in the clear tube at any time. The thermostat is new (old stock) so I don't think that is the problem. I took the plug out of the top of the water jacket and started it up. Alot of steam was pumping out of the hole but no water. The guy who sold me the motor told me he replaced the impeller every other season and he gave me a box of spare parts including several old impellers (and a few new) leading me to beleive he was telling the truth. Despite this, I'm thinking impeller is the next step and I'm a little nervous about pulling the lower unit but I know it must be done. I have a service manual for this motor with step by step instructions, but this manual has very little illistration to help me with this process. So, my question is, if you guys think impeller is the problem, what do I need to do this job? I have the new impeller, but what do I need as far as special tools, gaskets, lube, ect.? Also, what is anti-seize? , my manual says to apply this to driveshaft splines. Thanks guys.......
