the motor turns on and runs but is charging at 12.5v, the wires from the stator go directly to the voltage regulator and a generator wire from the regulator goes directly to the ignition switch. is there a way to check the regulator and the stator? when i put the ign. forward is there suppose to be voltage on the generator wire?<br /> thanks for any help
