CoachHolland
- Apr 20, 2004
- 165
On my 85 HP Force, I changed out the CD unit for cylinders one and two as well as the stator sensor underneath the flywheel due to some problems getting it started. Now it starts right up, however the #2 cylinder is dead and seemingly not getting any spark.<br /><br />I changed the #1 coil to the number two spot and hooked back up, but the #2 still isn't firing. The #2 plug always comes out clean (not steamed though, just wet from gas coating). Head gasket was recently replaced anyway.<br /><br />Compression is good on all cylinders. Last reading according to the mechanic was around 150 on each.<br /><br />I was told that it could be the second CD unit that controls the third cylinder since they "talk" to each other. Is this the case and is there any way to really check? I've already thrown way too much money into this engine and hate to throw another $200 away on the other CD unit if that's not what it is.<br /><br />Any ideas would be helpful.
