Can anyone advise of what the exhaust adapter plate bolts on the bottom of a 1995 force 40hp should be torqued at?? Is there any tightening sequence that should be followed?? Thanks.
Hi, ends.<br /><br />Welcome to iboats. <br /><br />I think you will get better response on a Troubles/Repair Forum.<br /><br />I will move this to the Chrysler/Force Troubles Forum.<br /><br />Good luck.
