3 cylinder single carb,<br />motor was running fine turning 5k at 39mph....<br />did some tight turns at slower speed but at wot<br />boat sort of spunout like a car would do so i <br />cut power quickly. motor started running rough at<br />idle and stalled, after which it took several tries<br />to get going caulse motor would stall when put in gear. after getting it going it would only turn<br />4500rpm at wot... carb butterfly is opening all the way at wot.. any ideas as too what happened???
