I am in the process of rebuilding this motor and need to bore it to 0.030" over. I can not find any pistons available in this size for this year motor.<br />I have been told to go and use 3 3/8" oversize pistons from a larger motor. These pistons do not have the two holes in the side but I can put those in. Has anyone had to do this before? A piston manufacturer has this piston available off the shelf. I could get this piston and check all of the critical diminsions. Is it worth my time?
