1994 Force 120, "dual exhaust" model<br /><br />Can barely move the engine with my shoulder! Cables and steering gear are disconnected.<br /><br />Seems that no lube makes it to the top of the "king pin" joint. I've heated it with a torch and that seems to loosen it for a while.<br /><br />My question is this; if I wanted to disassemble the "king pin" and clean it out how would I get to it? Can't figure out whether to start at the top or bottom! Also, are there seals or bushings that may need to be peplaced? I also plan on adding a second zerk fitting to the top.<br /><br />The manual doesn't show anything on this subject, so I'm hoping someone else has done this.<br /><br />Thanks! EEKSTER
