I have a 1989 force 85 hp that I want to hook up a overheat buzzer to.There is currently no buzzer on boat.Is there a way to test the sensor,,ohm's check,,etc.What kind of buzzer is Ok to use.Is this just a simple 12 volt circuit with the sensor completing the circuit when it overheat's.How tough is it to pull out the sensor,,it looks like just a snapring holding it in.Thanks for any and all info.
