I am pushing a 15 ft. Sportcraft with 2-cylinder 50 HP motor (507F7C). It initially worked well. Then, a few weeks later, I discerned a slight power loss at full throttle. That became a clear power loss noticeable at 3/4 throttle, then 1/2 throttle. And at 1/4 throttle. Then with minimal throttle, the power faded and the boat left me stranded and would not restart. I have guessed at coils, rectifier, stator, or voltage regulator as possible sources of power failure due to inadequate charging, as I have found the battery below 12.8 volts after getting stranded. Should I be recharging this (Nautilus 1000) battery each time I take it out, or should it be recharging itself if all electrical components are optimally functional? Do I start with a new battery or with electrical items ?
