Hola. Very helpful site. My first post. Water coming out of the pee hole should be warm or cold? After changing the impeller and thermostat water is warm. Normal? Thanks.
Re: 1989 Force 125 warm or cold water from pee hole
A friend of mine has an Evinrude and the water comes out cold. Would changing the water pump make the water come out cooler? Open for suggestions. Thanks.
