eurolarva
- Jun 24, 2003
- 4,182
Chrysler 45HP Model 45781. My understanding of my model number is 45hp made in 1967 the 8 means it has an alternator and the 1 means it was made in the US. <br />1. I hooked a DVM to my battery when I was running it today. At first batt showed 12.65VDC. After Gettting it started it dropped voltage to 12.35 which I am guessing because it is under load. If my motor has an alternator shouldnt I be seeing a voltage over 13VDC. I ran the motor at medium throttle for about 10 minutes and the charge slowly went up to 12.6 Volts. Is this normal or should I be seeing higher voltage when motor is running.<br /><br />2. I was told that I should keep my gas can full over the winter because water in gas can rust can. I dont understand this logic because I thought gas stayed on top of water and the rust would still be at the bottom. If I am suppose to leave gas can full what do I do with the old gas. I would think I dont want to run it through my chrysler because of messing up my carb.
