Force 120 1990 Overheat Buzzer Test
ridiver
I knew this once upon a time. Does anyone know which wires I would short together to test the overheat buzzer? Does the motor need to be running or can the key just be in the on position.<br /><br />thanks. :cool:
12Footer
Re: Force 120 1990 Overheat Buzzer Test
Key must be on. There should only be one wire hooked to the sender. Pull this wire ,and touch it to the motor frame. You should get buzzer.<br />The sender completes a path to ground when an overheated condition occurs.
