I recently purchased a 1992 Force 150. It had a brand new power Trim/Tilt pump and motor installed. The problem is that after raising and lowering the motor several times the 5 stainless bolts on the trim cyl. cap snap of when the motor reaches the top of the tilt. Mercury says the pump/motor should not create that much pressure. Apparently they haven't seen mine. Can anyone help, there aren't many experts around this part of the county.<br /><br />Thanks <br />Larry
