Just put the boat in the water after changing the water pump and head gasket. It would try to run right (sort of surging from time to time), but performed badly. Brought it home checked the plugs, and the #4 plug was super clean #3 was a little brown, and the top 2 looked normal (for about 1 hours use) compression checks out okay. I overheated a couple of weeks ago, which is why I did the pump and head gasket. Any clues??? The spark on #4 does not seem as strong as that of the other cylinders, but other than that, I can't see any other problem, Thanks a million, Greg
