Re: 89' Force overheat issue
Hi, Greg.<br />You stated, "I've pulled the pump, and though it looks bad, it should have been pushing some water. What would be a safe way to to try and flush the system out before I put the new pump in???".<br />It looks bad? Pieces missing? If so, they are in your motor no doubt. Pull the thermostat and while the lower unit is off, run a garden hose to rinse the pickup tbe and lower cooling circuit out. The upper end goes thru the exaust, so you would need to try to replace the tstat housing, and connect the hose to the pickup tube, to blow it thru the manifold.<br />Replace tstat with a new one.
