Re: HELP! chrysler 35hp shifting adjustment
ksab99,<br />I have a 1966 35 Hp Chrysler. Sounds the same as yours... After pulling the lower unit to check the water pump, I too had problems adjusting the linkage... Messed with it for days, and tried different things... It works OK for now, but still doesn't seem quite right... I can get reverse, but its a hard hit, and you can hear the gears... forward seems OK, but neutral is hard to find... If I ever figure it out, I will let you know... The manual doesn't give very much detail... I just kept trying and testing in the driveway before going out in the real water...
