Hello,<br /><br />I am working on a mid 1970's Chrysler 15 HP. Model number is 152 HC with a Tillotson carburetor # CO10B523 472061 1. <br /><br />When I got the motor it had a spark on one cylinder, changed the coil (another story in itself!). Now it has a reasonable spark when I ground the plug and turn the flywheel by hand (enough to see... and feel if not properly done).<br /><br />I put it on the boat, fired it up and put it in gear. It ran like it was only on one cylinder. Then it conked out and I got blisters from pull starting on it.<br /><br />It seemed like there was not much fuel getting to the cylinders (after all that pulling, the plugs were not very wet). Then it started backfiring (but not starting), and I rowed home<br /><br />The carb float was set about parallel to the carb body when held upside down, and I started the mixture screw at 1.5 turns (but tried many positions getting it to run).<br /><br />Now I know why I LOVE my 9.5 Evinrude.<br /><br />Any suggestions?<br /><br />Thanks,<br />TE
