Force 60 hp (1985)<br /><br />Okay here's the problem, the engine will start and run though it stalls if left to idle. The engine needs to be given alot of gas in order to keep it running while out of gear.Once it is in gear and moving the engine will surge fast and act like it wants to plane then acts like it is going into a stall then revs fast again. This fast to slow surging runs at about 2 second intervals. At first I couldn't get it to run at all without pumping the prime bulb while it was running. I replaced the fuel line and prime bulb and it helped but now I got this surging situation . Any Suggestions?<br /><br />GGrantTx
