Re: 1993 force 70 wont idle because it's missing
Hmm. Well, these engines have a weak area, the exaust port plates. They tend to warp when the thermostat sticks, or when the engine overheats, or the engine runs into quickly changing water temps, causing them to leak thru the exaust port plate gaskets, and into the combustion chamber.<br />A compression test won't allways fail in such a case, but if you have no compression, order the head gasket,plus a set of exaust port plate gaskets.<br />I pray you have no "holy-piston syndrome".<br /><br />Be carefull with torquing the bolts out, as they tend to "become one" with the block due to corosion.
