• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Power loss at full throttle
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Power loss at full throttle
    Have Chrysler OB 1976 35HP, last 1/2 inch of throttle bogs motor down, when checking linkage found no spark advance movement after that point but carburater linkage continues to move, there is room for adjustment to the spark advance linkage, would this possibly be a solution to my problem?
    Re: Power loss at full throttle
    May just need a carb sync, the carb throttle plates may be going past center.
    Help somebody every day, if you can.
