I need help with the torque specs on the following parts.<br /><br /> Head<br /> Rod Caps<br /> Exhaust Cover<br /> Crank Case Bolts-Large main bolts-Small Cover Bolts<br /><br />I have replaced all four pistons over a 5-year period. The fist time was pistons 2 and 4 now it is 1 and 2. Hint the new pistons have square rings and the OEM rings are tapered.<br /><br />Thanks <br /><br />Skybolt
