Re: overheat at high speed 1985 force 85 hp
So far, you haven't wasted any time or money. Those are the primary causes, and only last a couple years anyway, so changing them was a prudent move.<br />Try back-flushing the block with water pressure from the garden hose. It's hard to gett all areas of the system this way,so dissasembly will probably be needed.<br />There may be the pieces of the old impeller,or other obstruction in the cooling circuit...Buy a head gasket, and a set of exaust port plate gaskets, and inspect the water jacket.<br />It's a good idea to do this anyway on most outboards with many hours on them,esspecially,if said engine has seen a lot of salt water use.<br />Salt allways crystalizes in the water jacket. It can't be prevented, only diminished by frequent flushing and products such as "Salt-Away". <br />It may be "due" for a tear-down/ Look-see.
