• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
  • ALL iboats Forum Members and Guests:
    To show our appreciation for your participation in the Forums, we're offering an exclusive Forums-only discount good for an additional 5% off your iboats.com order for a limited time.
    To redeem, simply call our Customer Service Team at 800-914-1123 (Open M-F, 9am - 8pm Eastern Time) and mention the Forums 5% off discount. Offer excludes engines, trolling motors, and electronics.
Announcement Module
1. Please do not reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Please do not write in them.
2. Old threads should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone elseís thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
4. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
5. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when itís posted at the end of someone elseís thread. And those answers will be specific to your particular issue.
6. Please do not post to threads that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread.
7. Posting at the end of any thread is considered to be hijacking the original posters thread which in turn subjects the thread to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive thread asking you not to reply to old threads. The Red banner will read: Please note this thread has been inactive for 90 days. For the best results, please start a new thread.
See more
See less
Bad Impeller?
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Bad Impeller?
    Hi, OK, I got the motor (chrysler 45hp), running again and it stopped pumping water. I got the lower unit off after rounding off one of the screws, (that loctite really works), and running out to buy a bolt extractor...etc. My question is what should the impeller look like if it was bad/ The reason I'm asking is because it looks fine- is flexible, fits snug, no sign of wear really, and the little pin that turns it is there. I plan to replace it just curious if they usually break up when bad or what. Is there anything else that would cause the motor to stop pumping water? All the passages are clear. Just wondering if there is something else I should check while I have it apart.
    Re: Bad Impeller?
    Hi IRichYou cant see if it is bad. Usually one leaf suddenly breaks off, and takes a couple of others with it. Impeller can be worn,with rounded edges and still pump. If you ran it in barrel i guess water level got too low. when you stopped motor and restarted it wasnt able to catch water.The pump doesnt produce much vacuum.
    • #3
      Re: Bad Impeller?
      G-Dane is right. You can't realy see any damage until a blade breaks off, but you can look for some signs of a weak impeller. When you pull the impeller out of the pump housing, does the blades stay slightly bent? If the impeller has the rounded ends, does the outside look flat? An impeller that looks good, and might even pump water at a low RPM, can flex to much at a higher RPM and loose all vacume. I make sure that every year I replace the impeller, sometimes twice if I run the boat a lot.
