20' bayliner capri with rebuilt 120 force L-drive was working fine while breaking in new engine. used 25:1 oil mix for first 10 hours and it ran fine, just lots of smoke. now it hesitates at takeoff and sputters out of top carb at 3/4 throttle, sometimes not making it on plane. top plug is continually fouled, black soot, even after swapping from another cylinder. I do have good spark. thinking it must be carbs but I took them off and they look clean. could excessive oil continually cause just one plug to foul? Does the black soot on top cylinder mean it is not firing? It does occassionaly get going and once running WOT it does fine.
