1989 FORCE, 85 HP MISSING ON #1
Charlie Loehnis
85 HORSE 3 CYLINDER FINALLY GOT IT STARTED RUNS ROUGH, MISSING ON #1. DON'T SEEM TO BE GETTING ANY SPARK! PULLED #2 WIRE & HOOKED IT UP, STILL NO SPARK. DID SAME WITH #3-STALLED ENGINE! WHAT TO DO NEXT? PLANNING ON SWITCHING BRAINS FROM 1 & 2 TO SEE IF THIS MIGHT BE THE PROBLEM. WHAT DO YOU THINK? I REALLY NEED SOME HELP!!! READ ON ANOTHER TOPIC THAT SOMEONE LOST A MAGNET IN THEIR FLYWHEEL COULD THIS BE THE PROBLEM? HOW DO I FIND OUT? WHERE DO I LOOK? PLEASE HELP ME AS SOON AS POSSIBLE.COULD USE A LIST OF THINGS TO CHECK AND HOW TO DO THEM<br /> :confused:
Code:
lonewolf5347
Re: 1989 FORCE, 85 HP MISSING ON #1
swap wire's on cd from a good to no#1 if it fires the cd is bad.
lonewolf5347
FIRST THINGS FIRST WHAT YEAR IN THE ENGINE.NEXT THE CD IS MODULE THAT IS A POWERPACK THERE SHOULD BE TWO OF THEM ON THAT ENGINE.
sony2001
Each CD fires two cylinders. Since #3 failed switch wiring to the other wires on the same CD, the ones in place for #4. Do you get the drift? It will run. Then make friends with a 125 hp so when his CD has a failure you can keep it for your #3. lol :cool:
