• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
85 hp force outboard fuel/oil mix what is
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 85 hp force outboard fuel/oil mix what is
    i have a 85 hp force outboard motor. model number 856x7b. i need to know the year, anyone know? also what is correct oil/fuel mix? i dont believe its correct and it is running real ruff.please help someone.
    Re: 85 hp force outboard fuel/oil mix what is
    hey carvedman: Its a 1987 and the fuel/oil ratio is 50:1
    • #3
      thanks for the info. would you suggest draining the tank and starting over. and could this cause the motor to run like crap
      • #4
        Yes, its 50:1. If this motor is new to you, you need to perform some maintanance. I own the exact motor and with some TLC it has basically given me trouble free operation for the past 4 years.If you need help send me an e-mail to vze2mfqx@verizon.netAfter using the correct oil/gas mix you need to to a decarb and after that swap the plugs out. Also, change the lower unit oil. (THIS IS TRICKY) on this model. The drain plug is a very small allen wrench fitting on the front of the lower unit. If it doesn't come off e-mail me and I will tell you how to get it out.Use GOOD oil. I like Quicksilver Premium Plus 2 cycle.
        • #5
          Hey FTB I just bought a boat with the same motor but an 89 and I have 2 issues with it you might be able to help me with. It is hard to get going. Stalls allot. It has new plugs and stators. The other thing is the motor slowly sinks down. Is there a hydraulic adjustment.
          Thanks Rick
