Re: Force 90 Temp Alarm
salmon2 -- See Frank's analysis/response in the thread "overheating problems?". There is a range of symptoms....<br /><br />You probably shut her down quickly enough. Smoke isn't the best of signs, of course, but it's hard to tell what is OK in the way of smoke and steam from 2-cycle outboards. You need to correct the water circulation problem, and that should mean a new impeller. I think Lonewolf might be telling you to see if the engine is damaged before spending a lot of time or money on the lower unit, and that is good advice. If you are handy, though, you can change the impeller yourself for the cost of parts. When you get the impeller out, you will likely be able to see if it's the cause (broken vanes -- may find it in pieces). It's better to replace it anyway if you get that far, but the condition of the old one will give you a pretty clear idea whether you will need to look further to solve the cooling problem. <br /><br />If there is no visible damage around the head (scorching or paint bubbling), you are probably OK -- and you might be OK even with some visible signs. I don't think a new head gasket is necessarily needed. Chances are, you will fire it up with the new impeller and everything will work fine.
