• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
SplitFire Spark Plugs For Force 1995 70 hp motor
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • SplitFire Spark Plugs For Force 1995 70 hp motor
    Does anyone know what SplitFire plugs are for a 1995 70 hp Force motor and do these plugs make a difference or is it just Hype!-Joe
    Re: SplitFire Spark Plugs For Force 1995 70 hp motor
    I would suggest you do a search on this board for Splitfire. Read the posts, they have not gotten too many good comments. I suggest you stay with the recommended plugs.Bob
    This is a great link to boat specifications http://boatspecs.iboats.com/
    Please, shop iboats first!!
    • #3
      Spitfire??Egad!! no way,just hype. A single, fat, blue spark at the right time is all you need.Stick with fresh Champion premanant gap plugs as manufactuer recommends..,
      • #4
        Joe, the only thing splitfires will do is lighten your wallet.... a NGK BUHW surface gap, or perhaps a standard side electrode NGK B9HS-10 [@ .040"] if you are trolling with it...
        • #5
          NOT HERE I KNOW SOME CARS JUST DONT RUN GOOD ON THEY. I USED THEM ONCE AND NEVER AGAIN.
          • #6
            ODDD1 is right. Splitfire runs tooooo hot and will burn a piston in time. Believe me I've been there. Use Champion only....
