Re: '92 Force 120 torque-needle berrings
dwatt, I rebuilt a 90hp 90 model force motor a year or so ago, and I think that the torque spec would be the same. The only problem is, the bolt used on the rod bearings is , or was on mine, a 12 pt 1/4 inch bolt. I don't remember if I ever came across a 12 pt socket, but even if I did, I couldn't get it on bolt when it got down snug to torque. I had to use a 12 pt wrench that was open on one end and closed on the other. I bought it at auto zone. I couldn't find anything else that would get on it, and I just turned it as tight as I could turn the little thing with no cheater. I sold the motor to a friend, and it is still running with no probs. I am curious to know if your wrench has had the same prob. If you need them, I will get them for you in a day or so if you don't get them before. Let me know what you come up with. Good Luck.
