i have a 1994 that runs 130 degrees at ilde and up to about 2000 rpm, but then as the rpms increase the temp drops to below the gage reading, below 100. I replaced the thermostat, and spring. <br /><br />on this engine does the thermostat also act as a pressure relief? if so what pressure did force run in the water jacket?<br /><br />thanks<br />Ed
