• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
See more
See less
Prop nut torque
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • Prop nut torque
    Hi, I have a 1990 90 hp Force outboard on a 18.5 foot Bayliner Cutty Capri, and just pulled prop and lubed splines, etc. as seasonal maintenance. What is the correct propnut torque before bending down the nutkeeper's metal teeth into the washer slots?
    Re: Prop nut torque
    Frank, I believe that it is 55 ft lbs.
