• If this is your first visit to the iboats.com Boating Forums, be sure to check out the FAQ. To post a question or comment, begin by signing up. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
1992 Force 90 HP
Page Title Module
Move Remove Collapse
Conversation Detail Module
  • 1992 Force 90 HP
    I have a 1992 Riviera Cruiser 24' pontoon boat, I love it, but I have this terrible engine. Mechanic says the bottom chamber has no compression $1500 to fix, looks like I need a new power tilt and throttle as well. Should I dump the engine and repower? What engine do you recommend? 90 - 120 HP. What can I expect to pay? What is the best way to find out the value of a used boat and engine? Thanks!
    Re: 1992 Force 90 HP
    Hey Tater, To tell whether to repair or replace is usually determined by how well the motor was maintained. $1500 is alot less than a new motor, but if your present motor wasn"t taken care of , it might just be the start of many problems. There are many web sights that sell motors. To figure out what a used boat and motor is worth just click on the iboat.com classified under boat values. good luck
