pwlankford1
- Jun 18, 2001
- 3
I have an 88 Force 125 outboard. It will sound the alarm after high speed use and will shut off after the motor is shut off for a while or pour water on the head. It runs ok otherwise. Also, the breaker to the starter will trip when you turn the key on sometimes. Mostly when you push the key in for the choke it will trip everytime. <br /><br />Any suggestions<br /><br />I have: replaced t'stat.<br />also tried to replace pressure valve but broke the head off the bolt so I left it alone. It has good water flow coming out of the ports.<br /><br />Thank you
